Configure SONMP
Configure the SynOptics Network Management Protocol (SONMP) to allow a network management station (NMS) formulate a map that shows the interconnections between Layer 2 devices in a network. The default status is enabled.
    enable
    configure terminal
  2. Disable SONMP:
    no autotopology
  3. Enable SONMP:
    autotopology
Switch:1> enable
Switch:1 configure terminal
Disable SONMP:
Switch:1(config)# no autotopology
